In the video below we compare the standard TBC methods for placing Alignment Sheets and Extracting Data to the new PDF Manager command. You will clearly see that PDF Manager is >>2.25x faster (and way more if you have to extract data from the PDF), more accurate and far easier to use in this process (watch the Site and Alignment based project videos for a clearer review of the processes used to Georeference sheets).
