I am checking a storm system using QA Lines. I have two plan views using two different filters, one with the pipes only and one with the rim points and the drainage pdf in the background. I want the QA lines function working with the plan view that has the pipes only. When I run the QA Lines command all pipes data from this routine shows up in both views even though each view have different filters. I can send screen shots if needed.
Related topics
| Topic | Replies | Views | Activity | |
| QA Lines Command | 0 | 843 | August 17, 2022 | |
| Plotting Drainage Profiles | 7 | 632 | May 12, 2026 | |
| Multiple dynaview content boxes and view | 3 | 239 | May 4, 2025 | |
| Vertical Design Greyed Out Lines | 0 | 434 | May 19, 2022 | |
| Edit Sheet Sets - Profile and Cross Section - Manual Drafting | 3 | 837 | May 6, 2025 |
