Points to Cloud Report
- The Points to Cloud Report command is part of the RPS Tool Shed Toolbox.
- The command is located on the Tool Shed macros menu ribbon.
- The command is located in the QA / Point Clouds menu group.
Compares a selection of points to a point cloud region or scan to determine the nearest scan point to the selected points and provides a comparison between the derived point pairs. This is a useful tool to compare measured ground check points with computed point clouds from drone surveys to validate drone survey accuracy.
The following video shows how to utilize the Points to Cloud Report command:
COMMAND HISTORY
Update Information
SETUP AND EXECUTE
The Points to Cloud Report command dialog looks as follows:
Select the points that you wish to compare with the point cloud data. You can use the Options button to access the usual TBC Selection options, including Select by Layer, Select by Elevation Range, Advanced Select, etc.
Create points checkbox:
Check this checkbox if you wish to create 3D CAD points from the point cloud that are determined as the results of this process. If you check this checkbox, you will be prompted for the layer on which you want to create the points and the point number for the first point to be created, which will initiate a point number sequence for all of the check points to be created.
Search tolerance:
Input a search distance tolerance for the comparison between the selected points and the point cloud. The process will scan the point cloud to find any points that fall within the search tolerance (radius around each of the selected points) and determine the points in the point cloud that are closest to the selected points. The coordinates, distance (Delta XY), Delta Z, and Direction of the vector between the selected points and the extracted point cloud points will be determined and reported.
Number of scan points to report:
Enter the number of points around each selected point that you wish to report. The more points that you report, the more checks you have on the accuracy of the point cloud compared to the truth or ground control points in the analysis.
Example Points to Cloud Report
COMMAND TIPS
HEADER BAR COMMANDS
- Help - this document access
- RPS Settings
- Takeoff LInes
- Smart Edit
- Adjust Linestring Elevation
- Create Alignment
- Create Horizontal Alignment Labels
- Create Surface
- Add/Remove Surface Members
- Explore Object
- Measure
OK BUTTON
Executes the command, generates the report file (.CSV file), opens the report in Microsoft Excel, and then closes the command on completion.
CANCEL BUTTON
The following videos show the use of the Points to Cloud Report command in a workflow context:
If you would like to provide feedback on the use of the Points to Cloud Report command or to request enhancements or improvements to the command, please click Reply below.
