Points to Arc Command
Points to Arc
  • The Points to Arc command is part of the RPS Data Prep Toolbox.
  • The command is located in the Create / Edit menu group.
Provides the ability to create best-fit 3D arcs on planes defined by three 3D points. Great for architectural detailing from points measured with total stations or scanners.
The Points to Arc command dialog looks as follows:
Name:
Input the name for the arc that you are creating.
Layer:
Select the layer on which you want to place the arc object you are creating.
Coordinate 1, 2 and 3:
Select the three 3D points that will be used to compute the best-fit 3D arc object. Upon selecting the third point or clicking Apply the arc will be created.
APPLY BUTTON
When you tap Apply, the 3D arc will be generated and the command will prepare itself for another selection set and another process execution. If you do not want to make a second selection and repeat the process, tap Close to finish the process.
CLOSE BUTTON
The following video shows how to utilize the Points to Arc command:
The following videos show the use of the Points to Arc command in a workflow context:
If you would like to provide feedback on the use of the Points to Arc command or to request enhancements or improvements to the command, please click Reply below.
