Would this be an appropriate command to add the capability to create points at the center of closed linestrings? Maybe an option to extract name/feature code.
[D_PointCreator_600ppi] Point Creator
The Point Creator command is part of the RPS Data Prep Toolbox
The command is located on the Data Prep macros menu ribbon
The command is located in the Create / Edit menu group
Command Description
Provides the ability to create points for stakeout on lines and alignments at intervals, extra stations, key locations, high and low points, radius points and more
The command can also be used to create points …
