PDF Manager Georeferencing Improvement
On alignment based georeferencing
I would like the ability to overlay multiple plan sets and georeference them simultaneously. This is a common workflow on roadway projects where separate plan sets exist for roadway, removals, drainage, traffic, utilities, etc.
In many cases, the match lines already align between the different plan sets, but currently each set must be managed separately. Since the match lines and stationing generally correspond between these sets, a synchronized overlay capability would significantly improve efficiency on road projects.
Even if there is an initial process to match the vector points between plan sets, this would still be a significant improvement because I would only need to enter stationing information one time.
Can you send me a set of plans, the reference alignment and the sheet numbers that make up each page collection and a name for those like Phasing, Erosion Control, Existing, Design, Drainage etc.
If more than one alignment can ve seen in any plan sheet I will need all of the Lignments shown in the plan sheet.
Are these plan only or plan and Profile, do you want the profiles laid out also?
I have been looking at this exact issue and woukd be happy to try it next week on one of your datasets.
Sent them via Email.
