New Layer
- The New Layer command is part of the RPS Data Prep Toolbox.
- The command is located in the Layers menu group.
Utilizes the New Layer control to create a new layer or layer group and assign layer properties including the takeoff categorization, potential site improvement, and surface boundaries and associated site improvement attributes. The New Layer functionality is also incorporated into all RPS commands where a layer selection control is provided.
The New Layer command dialog looks as follows
Name:
Enter the name for the new layer. We recommend using names like ROAD - Curb Flow Line so that all ROAD features are grouped together alphabetically in the Layer Manager, etc.
Color:
Select the default color for the new layer. This will be applied to all objects that have their color set to “ByLayer”.
Linestyle:
Select the default Linestyle for the new layer. This will be applied to all objects that have their linestyle set to “ByLayer”.
Line Weight:
Select the default Lineweight for the new layer. This will be applied to all objects that have their lineweight set to “ByLayer”.
Layer group:
Select the Layer group for the layer. If you need to create a new layer group, you can do so here by clicking the [New …] button.
Enter the new Layer group name.
Click OK to complete the process and create the Layer group.
Click Cancel to abort the process and not create a new Layer group.
When selecting a Layer Group, you can use the layer group filter control to reduce the list of layer groups presented to those matching the character filter entered into the control. You can set the character filter to be case-sensitive also if required. Clicking the Layer Group selector pull-down arrow will show you the entire Layer Group list. Clicking the Layer Group filter will open the pull down list with the last used layer Group filter applied.
Usage Tip:
We recommend that Layer groups be named e.g., 00 - EXISTING or
01 - FINISHED GRADE, etc. so that they are sorted alphabetically in the View Filter Manager according to your work process, thereby placing the 00 - at the top of the list and 99 - at the base of the list.
Display priority:
Select the display priority for objects to be created on this layer. The options are Normal, Background, or Foreground. Objects will be displayed and printed based on this priority setting - Foreground objects will be drawn on top of Normal objects and Normal objects on top of Background objects. In addition, text is drawn on top of lines and lines on top of hatches, fills and images.
Protect layer checkbox:
Check this checkbox to add layer protection to the new layer. This will stop it from being deleted if you have no data on it and you ever select to “Delete empty layers” (e.g. in Project Cleanup or in Layer Manager commands. By protecting a layer, you also add it to the layers presented in the Standardize layers or Map layers commands.
Print checkbox:
Check the checkbox if you want the objects drawn on the layer to be printable. If you uncheck the checkbox, the objects on the layer cannot be printed to PDF or printer output.
Takeoff settings (Optional):
If you are using TBC with the Takeoff workflows, then as you create the layers you can also assign the required Takeoff attributes at the time of new layer creation.
Category:
Select the Takeoff Category that you wish to use the new layer for. For example, if the new layer will hold finished grade linework for, e.g., Edge of Pavement then you could assign the layer to the category Design. If the layer was to hold Existing Contours then you could assign it to Takeoff category Original. If it was to hold other data, e.g., Erosion Control Silt Fence linework then you could assign it to Category Other, etc.
Contains surface boundaries checkbox:
Check this checkbox if the new layer will hold linework that will be used to constrain a Takeoff surface (Original or Design surface). Line(s) used to form a surface boundary can be 2D or 3D and can be a single closed line or multiple closed lines that will form holes and/or islands in the takeoff surface.
Contains potential boundary lines checkbox:
Check this checkbox if the new layer will hold linework that will be used to constrain area-based site improvements. For example if the layer will hold road edge of pavement which will limit an Asphalt Pavement site improvement, then check the checkbox. If the layer will hold silt fence linework that will have no effect on any area based site improvement placement then do not check the checkbox.
MSI Manager button:
Click the MSI Manager button to open the Materials and Site Improvement Manager if you need to create or edit materials or site improvements to be assigned to this layer.
Site improvement:
If you want to automatically assign linework or points placed on the new layer to count, linear, linear with cross-section and area-based site improvements then you can select the site improvement here. For example, if the layer will hold points so that you can count trees for a landscape takeoff, then select the site improvement for trees from the site improvement list presented. If the layer will hold linework for striping, then you can select the striping site improvement here. If you intend to use the linework later and manually assign site improvements using the Identify site regions command, then do not select a site improvement here.
Note:
At this stage the site improvements have to be created in the Materials and Site Improvement Manager (MSI Manager) prior to running the New Layer command. We have not given the ability to create new Site Improvements from this dialog at this stage.
Usage Tips:
We recommend that you create a keyboard shortcut using CTRL + N for this command so that you can access it quickly from anywhere within Trimble Business Center.
APPLY BUTTON
When you tap Apply, the new layer is created and the command will prepare itself to create another new layer and process execution. If you do not want to create another layer and repeat the process, tap Close to finish the process. You can create as many New Layers as you need from a single execution of this command.
OK BUTTON
When you tap OK, the layer is created and the command closes with no further execution.
CANCEL BUTTON
The following video shows how to utilize the New Layer command:
The following videos show the use of the New Layer command in a workflow context:
If you would like to provide feedback on the use of the New Layer command or to request enhancements or improvements to the command, please click Reply below.
