Linestrings and Stationing
If you review the properties of a linestring, you will find that it doesnt have a station property unless maybe you have edited the line already with a Rockpile Command (we add the Station property to linestrings as soon as you edit them with our Smart Edit command).
To get the linestring property to show up on a linestring, prefix the name of the line with two underscores i.e. __Curb. as soon as you tab out of the field the Station property has been activated. You can now set the start station on the line to whatever value you need at that location.
Once the Station property has been activated, you can remove the two underscores as necessary.
Note that if you dont know the start station, but you do have locations along the line that have a station, if you use the RPS Quick Alignment command you can set the start station by setting a known station anywhere along the line as you convert the linestring into an alignment.
Video Shows You How
