Is there a way to generate a report on multiple linestrings at one time that will give you the name distances and vertical information? I am needing a way to compare my utility lines to the information in the plans? The information displayed under properties would be good enough.
Jonathan
Run the Geometry report from the command pain (GeometryReport command). That creates an Excel output with a Tab for each line selected and reports the full geometry of all Lines, polylines and Alignments selected.
