I’m having some issue getting my cross sections to stay within the area I’ve defined. I’ve messed with a lot of the settings, but some of the stations will have the sections drop below the XSEC grid. Which setting would I change to fix this?
Steve
Send me the project and I will take a look and let you know which setting is causing your issues here.
alan.sharp@rockpilesolutions.com
Thanks
I have had to set the vertical exaggeration to 0.5, and/or crop extents of the OG surface to hold tighter to the limits of the design surfaces.
As discussed yesterday Steve, the reason the sections were flooding below the grid was because you had a Vertical Exaggeration of 1.5, which resulted in the section data not fitting within the section grid, changing that to 1.0 fixed the issue in your project.
