Explode Text
- The Explode Text command is part of the RPS Modeling Toolbox.
- The command is located in the Sections menu group.
Explodes strings of offset label text in cross sections when they are merged into a single string in the data extracted from PDF files for the cross section takeoff workflow.
Example of string text from PDF:
The following video shows how to utilize the Explode Text command:
SETUP AND EXECUTION
The Explode Text command dialog looks as follows:
Texts to explode:
Select the strings of text that you wish to explode into individual labels.
Apply:
Click Apply to explode the selected text items. The text items will be exploded and converted into individual text labels that will then work in the cross section conversion workflow.
OK
Executes the command and closes upon completion.
Cancel
The following videos show the use of the Explode Text command in a workflow context:
If you would like to provide feedback on the use of the Explode Text command or to request enhancements or improvements to the command, please click Reply below.
