Name by Text
- The Name by Text command is part of the RPS Data Prep Toolbox.
- The command is located in the Modify menu group.
Names polygonal line objects using text data located inside the polygon. Used to name lots, pads, parking stalls, buildings, and other polygonal objects. This is a useful tool to prepare imported CAD data for field users of Trimble Siteworks or SCS900, etc.
The Name by Text command dialog looks as follows:
Lines and Text:
Select the closed line objects that you want to name along with the text objects located inside them that will be used to name the lines.
OK BUTTON
CANCEL BUTTON
The following video shows how to utilize the Name by Text command:
The following videos show the use of the Name by Text command in a workflow context:
If you would like to provide feedback on the use of the Name by Text command or to request enhancements or improvements to the command, please click Reply below.
