Convert to MText Command
Convert to MText
  • The Convert to MText command is part of the RPS Data Prep Toolbox.
  • The command is located in the Cleanup menu group.
Converts selected CAD text objects to Multiline Text objects. Multiline Text objects are smarter and have more flexibility in TBC than simple text objects for drafting purposes.
Note:
This is useful for upgrading legacy data (as well as some current data) into TBC Multiline Text so that you can use the Text properties like Bold, Italic, White Out, as well as Grips in TBC to resize, orient, and wrap text on screen.
SETUP AND EXECUTE
The Convert to MText command dialog looks as follows:
CAD Text objects to convert:
Select the text objects in your drawing that you wish to convert. The selection process will only select text objects.
OK BUTTON
Executes the command, converts the selected text to Multiline Text objects, and closes upon completion.
CANCEL BUTTON
The following video shows how to utilize the Convert to MText command:
The following videos show the use of the Convert to MText command in a workflow context:
If you would like to provide feedback on the use of the Convert to MText command or to request enhancements or improvements to the command, please click Reply below.
