Bore logs in 3d view
I have all the relevant date entered from an Excel csv file, the MSI and Strata defined. The bore hole do appear correct and in the proper locations. The bore is set to opaque and shows each strata at the correct color and depth. When you close the tab for “Import Bore Logs” the disappear from view in 3D.
How or can you see the bore holes in 3D without the Import Bore log tab open?
Thank you,
Jason
Unfortunately you can only see them while the command is open, however having you ask the question has triggered a possible solution to that going forwards - I will see what I can do.
If we do address this it will likely be in Smart Takeoff command - are you using that yet?
We have just updated our Smart Takeoff command to create BIM cylinders for the Boring Logs so that you can see them. I have to test it next week when I am back in the office
