Area, Length, Count Report Issues
When I select linework for silt fence to compute lengths in the Area, Length, Count Report I don’t get the same lengths as when I run the Take Off Report with site improvements. All of the lines are not showing up in the report. I find this issue with other linework as well. What could be causing this issue?
Can you share the VCL of the lines in question Brian
It could be that lines that have 0 elevation rather than Undefined or 3D are not reporting - would like to take a look
Alan,
I figured it out. I had the settings for the report to only show lengths. I didn’t know that this would eliminate lines that were closed. I changed the setting to show areas as well. This reported all lines closed or not and then I could get the total of all lines.
