Adjust LS Elevation - Enhancement Request
Please consider making the Surface selection drop down “sticky”. Thanks
You mean so that it remembers the last used surface each time you run the command ?
Yes please. It appears to default to the last surface in the list with each new call of the command and having it remember the last selected surface, when you have multiple surfaces in the project, would certainly be helpful.
