RPS Settings
Point Detail Report Settings:
For a full description of the Point Detail Report command Click Here
The Point details report command provides the ability to create report templates that can be applied to selected data in order to generate detailed point reports including any values defined in the report templates. You can create an unlimited number of report templates here that can be used on any project data.
Report definition:
The report definition field allows you to select any existing report from the list of available report templates so that you can review them or edit the template. Pull the list of templates down using the down arrow control or by clicking in the field. The report template details are provided in the Report Fields: area of the dialog.
Create a new template definition by clicking the button.
The New Report Definition Name dialog will be presented allowing you to name the new report definition.
Enter the name for the new report definition and click OK to complete or Cancel to abort the process.
Edit the name of an existing report template definition by clicking the button. The Edit Report Definition Name dialog will be presented.
Edit the name for the report definition and click OK to complete the process or Cancel to abort.
Delete an existing template definition by first selecting it in the Report definition field and then click the button
To edit the report definition fields, click the Edit Report Fields button.
The currently selected fields of the report definition are displayed on the left side of the dialog. The field column shows the field name and the Column Header shows the default value or edited value for the report column headers. If you wish to change a column header value, click in that field and enter the new value.
To change the order of the fields that have been selected, you can either left click select the field and drag it into the correct position or you can select the field to highlight it and then use the Up and Down arrow keys to move it within the list.
To deselect a field that is in the report definition selected fields list, select the field in the list and use the Right arrow key to return it to the Available fields list.
To add a field from the Available fields list, select the field in the list and use the Left arrow key to move it into the selected fields list. It will be placed directly beneath the currently highlighted field in the list.
When you are satisfied with your selections click OK to complete the process or Cancel to abort without saving the changes.
