RPS Settings
Highlight Colors Settings:
Highlight colors are used by commands like Geometric selection where the command requires a master selection and then also creates a sub selection from the master selection of data.
Primary Highlight Color:
This is used in commands like Geometric Selection as the primary selection color. For example if you select 1000 objects to sort through, they will be highlighted using TBCs default highlight color e.g. Magenta. When you define or apply a geometric selection filter those objects that meet the criteria defined by the filter will be highlighted in this Primary highlight color.
Secondary Highlight Color:
This is also used in commands like Geometric Selection as the secondary selection color. For example if you select 1000 objects to sort through, those objects will be listed in the table of selected objects. If you select a row within the table, the object selected will be highlighted graphically using the secondary highlight color.
