RPS Copy To Clipboard
- The RPS Copy To Clipboard command is part of the RPS Modeling Toolbox.
- The command is located in the Drafting menu group.
The RPS Copy to Clipboard command provides the ability to copy TBC data objects from a project in one instance of TBC into a project running in a second instance of TBC using the RPS Paste command. When an object is selected that has dependent objects, e.g., a surface model created from points and lines, the object and its dependent objects are copied to the clipboard using a virtual VCL file format.
VERSION DEPENDENCY
This command is 100% dependent on TBC v5.60 because it uses the Virtual VCL format capability that was introduced with this version of TBC.
SETUP AND EXECUTION
The RPS Copy to Clipboard command dialog looks as follows:
Select objects to be copied:
Select the project objects that you wish to copy to the clipboard. Click the Options button to access the advanced selection options, including Advanced Select, Select by Layer, Select by Elevation, etc.
In TBC v5.60, the command is linked to the keyboard shortcut CTRL + SHIFT + C. If you select data to be copied, using the shortcut will automatically copy the selected data to the clipboard.
If you copy data at the Plan Set, Sheet Set, or Sheet level from one TBC project to another, the RPS Paste command will create any missing Plan Sets, Sheet Sets, and Sheets to hold the copied data in the exact same structure as the source project from which the data was copied.
OK BUTTON
Copies the selected objects and their dependent objects to the Windows clipboard.
CANCEL BUTTON
The following video shows how to utilize the RPS Copy To Clipboard command:
The following videos show the use of the RPS Copy to Clipboard command in a workflow context:
If you would like to provide feedback on the use of the RPS Copy To Clipboard command or to request enhancements or improvements to the command, please click Reply below.
