There’s a few posts about how to remove the UCS of lines created in the cutting plane to add them to the world UCS. Is the reverse possible? I’d like to be able to create linework using the Linestring by Station command and then be able to edit those linestrings in the cutting plane view, or something similar where I can see that line, other lines drawn on that station, surfaces and points that have been snapped to that station.
Related topics
| Topic | Replies | Views | Activity | |
| Convert to LineString Removing Arcs while removing UCS | 9 | 120 | August 13, 2026 | |
| Linestring by Station? | 3 | 544 | July 30, 2021 | |
| Convert Linestring Command | 0 | 492 | February 1, 2021 | |
| Snap points to line | 5 | 262 | April 17, 2025 | |
| Adjust Linestring Command/Offset command | 2 | 432 | January 28, 2023 |
