All,
I am hoping this is an easy one. Can you do a Length Report that Utilizes Station?
I took shots along an Existing stone Trail and now I want to Report to the Engineer, the Width of the Stone at the station it was collected. Chat GPT Let me down.
Thanks,
Dave
If you have two lines for the edges of the trail, and you have some kind of alignment down the center or you can use one edge of the trail as the alignment, you can drop XLINES at intervals along the alignment and then use the Smart Edit Break or Trim / Extend to clip the lines back to the edges of the trail, then you can report the xline lengths as they are already at stations and that will give you the report you need. I have a Chat Script that measures the distance between two lines at stations so I know it is possible - it is in Cloud Services - it is the Rail Gantry check tool.
