Is there a way to find out the deepest Cut and the largest Fill? I am going to start creating some Cut/Fill maps for each of my projects and have picks color palette to use. I could just use the labels to view the cuts/fills. Thought I would ask if there was a different way.
Look at the properties for the CF Map - at the bottom of the properties it tells you the Min / Max elevations
FOUND IT… Thank you sir.
Awesome - amazing - small details can easily be missed!
