I like to use the takeoff cut fill mapping color codes, I’ve used RPS Volumes manager to Isopach 90 phased areas to generate cut fills per phase area. I’m curious if there is a way to default the color mapping so I don’t have to change 90 cut fill maps one at a time?
Barndon
We will try to address this when we get back to working on this command. At this time there is no easy way to do what you are asking. If you do an eartheorks report using the same 2 surfaces and the same 90 boundaries it should create a simgle isopach in the same arras and you can then remap the colors once
