Convert to Linestring - ByLayer issue
The command seems to be changing the (color) properties to “ByLayer” regardless if the box is checked or not.
I use the command to vertice weed TBC generated contours and it changes the index contour color to ByLayer.
It is a pain that you can’t set a separate layer for the index contours.
Personally, I prefer the index/inter contours on the same layer just different colors. It’s not often, or ever that I can recall actually, that I’d want to display one without the other. I just can’t have the commands changing the properties unless expected.
There is an update to Convert to Linestring that addresses this issue this morning Richard - it should be released shortly
Thanks, as always, to you and the RPS team Alan.
