Two out of three of our TBC users cannot publish files using WorksManager in offline mode. When sending the data using the Field Data to USB the files and folder will not be generated in the designated file location. Does anyone have any ideas?
I would recommend using the construction data workflow and then replacing the DSZ with a VCL through the Project Link Exporter. I haven’t had a great experience with the workflow you mentioned.
the correct drive is being selected?
