In this video we explore how to navigate AutoCAD files that you import into TBC and have until now never seen the data. In many cases, you may be provided with a Master CAD file that has XREFs to many other CAD files that get loaded graphically along with any data in the Master CAD file. The XREFs are all separate drawings and can be “located” in the same area as the project or can be located in a completely different location and in some way, AutoCAD when it references them together it knows how to shift and rotate the DWG data into the “correct” geolocation, however TBC does not know that information because it is not reading the XREF data so it imports them in the true location of the file as defined by the individual DWG files. This creates an issue when you pull all the data together in TBC, and in some cases makes finding the required data hard to do.
Hope the video helps
