Volume on Cut Fill Map
I noticed a post on another forum back in Feb that mentioned using smart text to label the actual volume on a grid along with the cut fill values. You also showed an excel report to accompany this. Is this something you are currently working on? It would be nice if there was a label or number for each grid cell that was also in the csv report. This would really helpful in the bidding and performing of the projects. Similar in thought to mass haul.
Thanks,
Brian Sarvis
It is on the list of things to do Brian
You can do the Total Cut and Total Fill and Balance as Smart Text, but labeling the CF Grid with Cell Numbers and Cell volumes is on the list to address sometime in the not too distant future.
Thanks Alan. I look forward to it.
