Utility Modelling
Is it possible to get a TML to have the option to adjust your vertical pipe location. I would like to be able to take the utility pipe that is generated from multiple nodes due to changing slopes. As of know if you pick one of the settings for for the vertical location it will only adjust the 2 end Nodes. Work around is to drop your line string a vertical distance. Which the points that were collected will remain at the Top of Pipe or invert etc. I submit the 3D network to U dot for the final submittal. I could also drop the points a given vertical distance as well. Was looking for a quicker workaround for this.
