When doing a takeoff, I have material being salvaged, but if I want to reuse some of that material, I show quantifying it as a demo material first and then I’d like to use that material as site improvment materail in the design portion. How would I re-insert that material to become quantified properly?
I think the way you could accomplish this is by using a processing site for the material youre using via site mass haul
Try using a material set
If you have a material called Demolition you can try making a material called Reycled Fill that you then use as a fill material(if it goes into a subgrade or if you are just mi ing it into a fill then you may need to create a material called fill using materials like the demolition material and the native strata materials
I have not done that myself in a Takeoff but it may work
