TBC Request - Georeferenced Image - Clipping Boundary Rotation Component
The new rotate plan view capability is awesome! Thank you for the tools for this! One command that would benefit from a rotation component when working in the rotated views is the clipping boundary for Georeferenced Vector PDFs.
Disclaimer you can work around this with the image boundaries however sometimes you just need a simple box like shown above and the clipping boundary works well and helps to keep things simple.
This actually works well. I use it quite often on our long corridor jobs. Clipping using the alignment boundary which keeps everything the same and overlays nice. I rotate if needed and use the match lines to join the pages.
