TBC - Free Viewer
The following commands are included in the Free Project Viewer version of Trimble Business Center
Field Data Support - Survey
Access Services
Device Pane
External Processing Services
Send to RTX-PP
Trimble Access Services
Trimble Sync
Trimble Sync Manager
Field Data Support - Construction
Add External Job Site Design
Compress/Email Field Data
Publish Field Data to Project Library
Copy Field Data to Data Card
Copy Field Data to USB Flash Drive
Copy Project Library to USB Flash Drive
Copy Work Order
Create Job Site Design
Create Vision Link Project
Create Work Order
Delete Work Order
Export Field Data (Trimble Machine Control)
Export GCS900 Excavator Profile Files
Export GCS900 Machine Avoidance Zone File
Export GCS900 Machine Jobsite Design
Export GCS900 Machine Site Map
Import Work Order Results
Import GCS900 .avoid Format
Import GCS900 .avoid.svl Avoidance Zone Files
Import GCS900 .cfg Coordinate System Files
Import GCS900 .dsp Format
Import GCS900 .mch Format
Import GCS900 .mch Measure Up Files
Import GCS900 .persist Format
Import GCS900 .pro Format
Import GCS900 .svd Files
Import GCS900 .svd Format
Import GCS900 .svl Files
Import GCS900 .svl Format
Import GCS900 .tsd Format
Import SCS900 .gcj Work Order Files
Import SCS900 .ini Site Settings File
Import SCS900 .spj Work Order Files
Import SCS900 .txt Work Order Results File
Job Site Design Manager
Job Site Manager
Process SCS work order symbols
Publish Field Data To Business Data Center
Publish Library to USB
Publish to Vision Link
Reassign External Job Site Design
Reassign Work Order
Work Order Editor
Work Order Report
Work Order Report
Work Orders Summary
Utility Applications and Connections
Connected Community HCE
Coordinate System Manager
Feature Definition Manager
Google Earth
Office Synchronizer
Online GNSS Planning
Planning
SCS Data Manager
VisionLink
Trimble Web Services Support
Open Remote File
Save File Remotely
System Level Tools
About Trimble Business Center
Archive Project
Check for Updates
Close Project
Command Pane
Compute Project
Coordinate Scroll
Define Command Shortcuts
Exit
End-User License Agreement
Help
Import/Export User Options
License Manager
Open Project
Options
Register Software
Start Page
Tours and Tutorials
Workflow Guides
Data Views and Controls
3D Preset Views
3D View Projection (Perspective vs. Ortho)
3D View Settings
Activate Limit Box
Back
Backward Planar View (Backward Camera View)
Bottom
Bring Forward
Bring to Front
Center
Cutting Plane View
Defined Views
Edit Limit Box
Flags Pane
Float View
Front
Go To Run Position
Left
Left Mouse Pan
Left Mouse Rotate
Left Mouse Select
Left Mouse Zoom
Move to Next Tab Group
Move to Previous Tab Group
New 3D Drive View
New 3D View
New Cross-Section View
New Default Project
New Horizontal Tab Group
New Plan View
New Plan View (old architecture)
New Profile View
New Project
New Station View
New Station View (referenced images)
New Vertical Tab Group
Orthographic
Pan
Pan Precise
Perspective
Plane Manager
Process View
Profile Viewer
Send Backward
Send to Back
Set Limit Box
Side Planar View (Side Camera View)
Station View Image Filter
Surface Slicer View
Tile Sequence Viewer
Presentation Mode
Project Settings
Run Last Command
Save Project
Save Project As
Save Project As Template
Selection Explorer
Set Menu Layout
Toggle Gridlines
Toggle Line Marking
Toggle Visibility
Toggle Z-Axis
Top
View 3D Preset Last Used
View Filter Manager
View Mission Trajectory (Toggle Trajectory)
Walk-Through
Zoom
Zoom Extents
Zoom In
Zoom Out
Zoom Precise
Point Cloud Controls
Colorize Scans
CAD and Inquiry Tools
Delete
Explore Object
Filter Line Markings
Invert Selection
Layer Group Manager
Layer Manager
Material and Site Improvement Manager
Measure Angle
Measure Distance
Measure Point
Polygon Select
Project Explorer
Properties
Rectangle Select
Redo
Right
Select All
Select by Layer
Select by Polygon
Select Points
Snap Mode
Undo
Data Conversions
Convert TGO Project
Convert to RINEX
Export Functions
Export rcp Point Clouds (Autodesk recap)
Export SIMA Format
Export Sketchup .skp Files
Export Somero .nod Files
Export Survey Controller Job File
Export Survey Data Collector DC File
Export Survey Pro Job File
Export TDS Interlock (ilj) File
Export Trimble Access job File
Export Trimble Access Road Strings
Export Trimble Access RXL Road Templates
Export Trimble JobXML Field Software Format
Import Functions
Import
Import .asc ASCII, TDEF, Raw Data, InRoads Hz and Vt Alignment Files
Import .CAL Site Calibration Files
Import .dat DiNi Level Files
Import .dat STAR*Net Level Files
Import .eje MDT Hz Alignment Files
Import .inf Fast Survey Files
Import .pbj Rangefinder Laser Files
Import .raw (TDS, Nikon) Raw Data Files
import .sp3, sp3c precise ephemeris files
Import .xyz point Cloud Files
Import .yxz Point Cloud Files
Import ASCII CSV Files - PNEZD
Import ASCII CSV Files - Station, Offset, Elevation
Import Ashtech ProMark / ProFlex .crd Format
Import Ashtech ProMark / ProFlex .ddd Format
Import Autodesk DWG Format
Import Autodesk DXF Format
Import Bentley .icm.dgn iModel Files
Import Bentley Microstation dgn files
Import Business Center - HCE .VCL Project Link Files
Import CaAiCE .txt Files
Import Cartomap .txt Files
Import CLIP .alz Alignment Files
Import CLIP .plt Alignment Files
Import CLIP .trv Files
Import e57 Format
Import Fast Survey .sys Files
Import Format Editor
Import Geopak .xsr Cross Section Report File
Import HYDROpro .hpt Files
Import IFC Files
Import Inframodel .xml Files
Import InRoads .soe Files
Import IREDES .xml Tunnel and Drill Plan Files
Import ISPOL .ali Alignment Files
Import ISPOL .ras Vertical Alignment Files
Import ISPOL .sce and .sc1 Files
Import LandXML Format
Import LAS Format
Import MDT .ras Vertical Alignment Files
Import MDT .tra Files
Import MX GENIO .crd, .mos, .txt Files
Import NGS .ds Data Sheet Files
Import NGS .htm Data Sheet Files
Import NGS OPUS .xml Files
Import Norway .KOF Files
Import Norway .tit Files
Import Novapoint .gen Files
Import Novapoint .vgp Files
Import PCS900 .persist Display Configuration Files
Import Penmap .pdt Format
Import POD Format
Import PTS Format
Import PTX Format
Import RCP Format
Import REB .021 Files
Import REB .040 Files
Import REB .066 Files
Import REB .66 Files
Import Report
Import Report
Import SBG .geo Files
Import SBG .gt Files
Import SBG .lin Files
Import SBG .llc Files
Import SBG .lmd Files
Import SBG .nyl Fles
Import SBG .prf Files
Import SBG .pxy Files
Import SBG .sec Files
Import SBG .skv Files
Import Sitepulse .epj Work Order Results File
Import Sketchup .skp Files
Import Somero .nod Files
Import SOSI Format
Import Spectra Precision Field Surveyor .dat Format
Import Spectra Precision Field Surveyor .xml Format
Import Spectra Precision Field Surveyor ASCII Format
Import Spectra Precision Focus DL-15 Level Files
Import Survey Pro .job Format
Import Survey Pro .raw Format
Import Survey Pro .survey Format
Import Survey Pro .xml Format
Import TDS Interlock .ilj Format
Import Terramodel PRO Files
Import Trimble .dat GNSS Files
Import Trimble .dc Data Collector Files
Import Trimble .dc Site Calibration Files
Import Trimble .FXL Feature Code Library Files
Import Trimble .pav Paving Run Files
Import Trimble .RXL RoadXML Files
Import Trimble .tdx Data Exchange Files
Import Trimble .tsf Scanner Files
Import Trimble .ttm Surface Model Files
Import Trimble Access .dc Format
Import Trimble Access .job Format
Import Trimble Access .jxl Format
Import Trimble Access .rxl Format
Import Trimble Access .xml Format
Import Trimble Digital Fieldbook .dc Format
Import Trimble Digital Fieldbook .job Format
Import Trimble Digital Fieldbook .xml Format
Import Trimble GNSS .dat Format
Import Trimble GNSS .t00, .t01, .t02 Files
Import Trimble GNSS .t00/.t01/.t02 Format
Import Trimble Survey Controller .dc Format
Import Trimble Survey Controller .job Format
Import Trimble Survey Controller .jxl Format
Import Trimble Survey Controller .rxl Format
Import Trimble Survey Controller .xml Format
Import Trimble Survey Manager .jxl Format
Import Trimble Survey Manager ASCII Format
Import Trimble Survey Pro .survey Files
Import Wirth .yxz Files
Reports
Quality Assurance Report
Stored Measurements Report
