Takeoff Summary Report TBC
We opted out of updating our TBC installations to 2023.10 mostly because of the removed reports.
One option to consider is Alan’s guide on how to install multiple versions of TBC to your computer at once, then you could use the current version but fall back to an older version for running reports etc.
To get around the issue of a project having been saved in a newer version of TBC, you hold down Ctrl+Shift while drag-dropping the project file into the older version of TBC.
https://community.myrockpile.com/t/working-with-combining-spirals-and-station-equations/1768#:~:text=use%20CTRL%20%2B%20SHIFT%20key
Hope this helps.
