Switch Text
- The Switch Text command is part of the RPS Data Prep Toolbox.
- The command is located in the Modify menu group.
Switches text properties between two selected text objects. Text properties include height, width, text, rotation, oblique angle, justification, aspect ratio, layer, color, etc.
The Switch Text command dialog looks as follows:
Text 1:
Select the first piece of text in the graphics area
Text 2:
Select the second piece of text in the graphics area
Switch Options
Check any or all of the following text properties that you want to switch between Text Item 1 and Text Item 2
[ ] Text (the text content itself)
[ ] Height (the height of the text)
[ ] Width Factor (the width factor of the text)
[ ] Rotation (the rotation angle of the text)
[ ] Oblique Angle (the oblique/slant angle of the text)
[ ] Justification (the justification location of the text)
[ ] Aspect (the aspect ratio (height-to-width ratio) of the text)
[ ] Layer (the layer on which the text is placed)
[ ] Color (the color of the text)
APPLY BUTTON
When you tap Apply, the text properties will be switched and the command will prepare itself for another selection set and another process execution. If you do not want to make a second selection and repeat the process, tap Close to finish the process.
CLOSE BUTTON
The following video shows how to utilize the Switch Text command:
The following videos show the use of the Switch Text command in a workflow context:
If you would like to provide feedback on the use of the Switch Text command or to request enhancements or improvements to the command, please click Reply below.
