Surface Tie - Multiple Reference Lines
Would it be possible to create a command that could create multiple surface ties & surface?
This would be helpful when you have multiple base excavation on a project, to calculate the individual volume of each (Rapidly)
Process would be
  1. Select Reference Line
  2. Offset Ref Line (working Space)
  3. Create multiple base surface (using the name field & a prefix for the surface name)
  4. Create multiple surfaces tie, which attaches to each surface
  5. Run volume report for all base excavation
The current project has 70 bases like this to do, is there a better workflow to do this quickly
