Surface Slicer & Pipe Networks
When using the surface slicer, is there a way to not only turn off surfaces, but also to turn off pipe networks? It would be a nice feature to be able to turn off the pipe network when drawing surface slices.
There is no way that I know of to turn these off in a single TBC Project today. If you build the Utilities in a second project and use Reference Files then you can turn off the Utility Reference File and they would not show in the Surface Slicer View of the Master Project
Sorry that I dont have an answer for you around that
That’s a good workaround, thanks for the insight Alan.
