Spot Elevation?
Is there a way to get an on the fly precise spot elevation off of a corridor or surface model? Using the scroll bar you have to hover over the area an it is not as precise. Running Version 5.30 at the moment.
You could use smart text. This way you can snap it to a specific spot and then drag it to a new location.
Its too bad you can’t favorite common codes that you use for quick access.
You can get Station, Offset and Elevation for a Corridor Surface using Explore Object - have you tried that - select the alignment s the reference object - then you can click anywhere and extract the data that you are looking for
