Smart Text - Delta Elevation
Is there a code for delta elevation of a segment?
What is delta elevation of a segment do you mean the elev diff between the two ends?
Not that I know of - in eg QA lines we could compute that and display it I guess.
Correct elevation difference between node end points.
I was trying to use this for marking up a profile sheet. Few other scenarios that I have found that this would be useful.
Pipes
Lines
Walls
