Often in CAD and PDF extracted data, you will find multiple lines that sit on top of each other to varying degrees, that collectively follow the path of a single line. Sorting these out and creating a clean, single, continuous line can be a time consuming process. Join Overlap mode helps you by providing a fast and effective workflow to create a continuous line and remove the parts of lines that it does not need.
Video shows you how
