Smart draw doesn't close
We’ve had issues with a few drawings that we eventually realised the common factor was using smart draw vs using the standard poly line tool to create LOD bounding lines. When we use the Polyline tool, the bounding lines close or can be closed by checking the close line box. When we use the smart draw, even when we have it ticked for the line to be closed, when we go to identify site improvements it doesn’t consider those lines actually closed. When we redraw the line with the polyline tool, it immediately works again.
PS. We have also attempted to go back and join the bounding line LOD to see if that might be part of the issue and had no luck with that.
Is this a setting/tool issue or some good ol’ operator error?
Let me try it to see - something may have changed inneg 2024.1 that we have not noticed - let me check
