Is there an equivalent tool or work flow to the Slope Slope Intersect Command for use in the corridor template work flow? I would like to be able to automatically calculate and adjust subgrade shoulder PIs for perpendicular offsets to a final grade. I’ve tried the slope slope instruction, but it fails to generate the type of node necessary for the second perpendicular offset.
The Slope Slope Intersect Command appears to do what I am looking for but would require creating the corridor then creating the subgrade via plan lines.
I apologize in advance if this topic has previously been covered.
