Simple Parabola for Bridge Beams
I would like to see a Simple Parabola to put in the bridge beam deflections. Select the beam and add the deflections to the beam points. I agree with the other post, Select beam divide by an even spacing create the points and apply the deflections to finish grade or an offset. This would actually let us do all of our work in TBC instead of using a spreadsheet.
Shea
Possibly add an option to extend/offset deflection grade for edge of deck or between beam. Then build a simple surface from deflection.
