Hello.
Is there an easy way to show in a plotted form, the deviation of field surveyed points in a grid pattern (4’x4’), compared to the design finish floor surface?
Thanks
Brian
Hello.
Thanks
Brian
I use the RPS Label Points command to label the points and color code the labels based on tolerances, that will also generate a Report Output also.
If you have the Design Surface and the Grid of measured check shots this works well.
You can also use the Corridor As Built Report - Draw an alignment parallel with one of the sides of the floor and then you can report the points using the Corridor As Built Report - the format is different but some people like that format of report.
