Hey All,
I am going through the tedious process of selecting line arc of a corridor and adding/removing surface members to swap them to my desired surface. I want my surface lay ON so I can see which line my surface is snapping to, however each time i select the line (because this is a repetitive process) i have to select between the line, surface or adjacent line. Is there any way to still see my surface but be able to select the line I want initially making my selection process much quicker?
