RPS Tracker Work Orders Command
- The RPSTracker Work Orders command is part of the RPS Tool Shed Toolbox
- The command is located in the Earthworks menu group
Command Description
Copy Command Description from Data Sheet Here
The XXX command dialog looks as follows
Place picture of command dialog here
Dialog Input 1:
Describe Dialog input 1 here
Dialog Input 2:
Header Commands
- Help - this document access
- RPS Settings
- Takeoff Lines
- Smart Edit
- Adjust Linestring Elevation
- RPSTracker Website
- Create Surface
- Add and Remove Surface Members
- Add and Remove Surface Boundaries
- Create Boundary
- Create Plotbox
Apply
When you tap apply, XXXXX and the command will ready itself for another selection set and repeat process execution. If you do not want to make a second selection and repeat the process tap Close to finish the process.
OK
Close
Cancel
Video Demonstration
The following video shows how to utilize the XXX command
Use Case Videos
The following videos show the use of the XXX command in a work process context
If you would like to provide feedback on the use of the XXX command or to request enhancements or improvements to the command please Click Here
