RPS Rock Deck Configuration for the Elgato Stream Deck XL
Rockpile Solutions is pleased to announce the incorporation of the Elgato Stream Deck XL into our portfolio of productivity boosting solutions for Trimble Business Center users.
For more details about the Elgato Stream Deck XL - Click Here
The Stream Deck device provides a customizable 32 key multi page keyboard that has been specially configured by our development team to create Rock Deck configuration, optimized for Heavy Civil contractors doing Takeoffs for Estimating and 3D Models for Machine Control.
The Rock Deck provides hot key access to all of the commands that you use to carry out your work process.
Each page of keys is dedicated to one of the major steps in the workflow
- Home - Managing your System
- PDF & Image - Importing and Georeferencing PDFs and extracting linework
- Data Prep - CAD Cleanup, Explodes, Layer Controls, Exports and Advanced Tools
- Elevate - Elevating Data
- Model - Creating Surface Models and Designing Slopes and Surfaces
- Takeoff - Doing Takeoff Calcs and Reporting
- Roads - Corridor Modeling
- Plot - Creating Plot Sheets and Drawing Outputs
- Utility Modeling and Takeoff
- Photogrammetry and Point Cloud Processing
- QA / QC processes
- Field Operations
- RPS Top Tools
On each page you will find all of the primary functions of the work process and quick access to all of the following, because these are often required no matter the work process you are executing.
- CAD Tools
- Drafting
- Views
- Measure and Explore
- Selection Methods
- Layer Management
- Reporting
- Exports
Command Control and Data Entry Keys
In addition you will also find
- OK / Enter and Esc / Cancel keys
- RPS Keys - A custom data entry keyboard optimized for entry of coordinates, bearings, slopes along with all necessary keys for tabbing, back tabbing, numeric and alpha numeric entry etc.
Hot Keys
In addition all RPS Command Hot Keys are now available on the Hot Key button making it an easy one click process to
- Rotate the plan view (Normally Q, E or SHIFT Q, SHIFT E keys)
- Pan the Active View (Normally W, A, S, D keys)
- Increment or decrement values (Normally Z and C keys)
- Reverse the Increment/Decrement direction (Normally SHIFT Z and SHIFT C keys)
- Pop up the by cursor edit control (Normally X Key)
- Turn on and off Vector snaps (Normally V key)
- Start a new process (e.g. new line) (Normally N Key)
- Activate Rock Grip editing (Normally G Key)
This eliminates complex Multi key keyboard controls and improves speed and user experience.
Key Benefits of the Stream Deck
- All Work Process command functions are only 1 or 2 clicks away no matter where you are in the Stream Deck
- Navigation and command execution is faster using the Stream Deck than using menus and Shortcuts that no-one can remember.
- Users can quickly transition between work processes and then easily find the primary or secondary commands that they need to use, all organized in a work process or work type sequence. When you need a CAD Tool or data entry - a single key press gives you instant access to all those functions.
- What’s more you can further customize the Stream Deck with additional profiles to support use of other applications like Word, Excel, Websites, Social Media Sites and more.
- Each key carries the correct command icon as well as text telling you which command will be executed making it easy to learn and follow.
We believe that the interface
- Aids learning TBC workflows
- Makes TBC faster and simpler to use
- Increases your personal productivity
- Eliminates the use of menus, Toolbars and Shortcuts
- Increases screen real estate
- Provides an optimized data entry keyboard for keying in coordinates, elevations, station and offset, latitude, longitude, bearings and distances, slopes, feature codes, names, text and point IDs.
- Provides easy to use Hot Keys and Shortcuts
- Keeps your focus on the graphics area and keyboard and heavily reduces clicks and mouse movements
- Controls the entire TBC product in an easy to setup and install configuration
Pricing & Availability
Rock Deck configuration Price $275
Elgato Stream Deck Price $275
Combination Package $550
Corporate License - Rock Deck Configuration $1000
Plus shipping and Sales Tax at Cost for all Stream Deck Orders
Pricing is a one time purchase cost, all Rock Deck updates will be provided as they are released.
Availability
Available now
