RPS Extract Surface Features Issue
Since I started using the Extract Surface Features command I have been having an issue where when I use it even though I create a new layer for the extracted surface features the command seems to always put everything on layer 0. I have double, triple, and quadruple checked my settings before running the command but nothing seems to change. I’m wondering if this is common with this command or am I overlooking a hidden setting somewhere. I’m not sure what else to try any help would be much appreciated.
I’m unable to reproduce this on my end. Have you updated your TML’s since our last release? If you go into TML Status, the version of all tools should be 2025.4 for everything. If that’s not the case, grab a fresh install package and install, try again and let us know if you are still having an issue. If you are, I’ll hop on a call and see if I can figure out what’s going on.
