RPS Export XML
- The RPS Export XML command is part of the RPS Tool Shed Toolbox.
- The command is located on the Tool Shed macros menu ribbon.
- The command is located in the Exports menu group.
Exports selected linestrings and alignments as 3D curvilinear alignments to LandXML format for use in Trimble Access and Leica stringless paver systems.
The command has been designed to work in combination with the Optimize Linestrings command that converts chorded horizontal and vertical linestrings into 3D curvilinear lines that have been optimized for use on stringless pavers from Leica. You can also create the lead-in and lead-out extension lines using the RPS Extend Lines command prior to selecting them here for export to XML format.
Note: The LandXML file created by this method is designed for compatibility with the LandXML schema and also the format expected by the Leica stringless paver systems. This format is different from the format created by the standard TBC LandXML exporter from the same data.
Note: The Leica Slipform Paver system requires that all exported alignments start at Station 0.
Note: The Leica Slipform Paver System requires that the lines that will be used as a pair (master alignment line (used for station and elevation control) and a secondary alignment (used for cross-slope control)) must be drawn in the same direction in order to be used together; they will fail to work otherwise.
The format output has been tested with Leica iCON systems and we are currently validating with Leica MC1 systems.
One user has suggested that it is helpful to name the alignments clearly to make it easy for the paver crew to understand the alignment naming. They also manually convert the linestrings to alignments in TBC prior to outputting them so that they can name them and check the alignments in the alignment editor prior to exporting them to the Leica machine systems.
The following video shows how to utilize the RPS Export XML command:
COMMAND HISTORY
Command Updates
March 2023
- The command has been updated to write International Foot project data in International Foot units. All units are now fully and correctly supported. Prior to this update, International Foot data was converted to US Feet and exported with the correct header information in the LandXML, so the LandXML file was correct but was not in the same units as the source TBC project.
June 2023
Added header bar commands for the Slipform Paving Work Process including:
- Optimize Linestrings
- Explode Lines
- Extend Lines
The RPS Export XML command dialog looks as follows:
File name:
Enter the file name for the LandXML file to be created. If you right-click in the file name field, you can select Browse to navigate your computer’s folder system or open the Project data folder for the currently open TBC project. If you click the […] button that will also open the Project data folder.
Select objects to export:
Select the curvilinear lines that you wish to export to the LandXML file. If you wish to use the advanced selection options, click Options to Select by Layer, Select by Elevation, Advanced Select, etc.
HEADER BAR COMMANDS
In the header bar of the command you can find quick access icons for command help, RPS Settings, and the the slipform paving workflow commands including:
- RPS Help
- RPS Settings
- Takeoff Lines
- Smart Edit
- Adjust Linestring Elevation
- CAD Cleanup
- Profile Viewer
- Explode Lines
- Extend Lines
- Affix Name
APPLY BUTTON
When you click Apply, the LandXML file is exported and the report is generated in the Reports section of the dialog. The command will prepare itself for another selection set and execution. If you do not want to make a second selection and repeat the process, tap Close to finish the process.
CLOSE BUTTON
The following videos show the use of the RPS Export XML command in a workflow context:
If you would like to provide feedback on the use of the RPS Export XML command or to request enhancements or improvements to the command, please click Reply below.
