RPS - CAD Cleanup Command: Designed to make your life easier in working with CAD files, this command allows you to:
*Explode and Delete Blocks - Individually or all at once.
*Delete AEC Objects
*Delete Zero Length Lines
*Set text to stroke fonts
*Convert to Multiline Text
*Delete Empty Layers
*Make Low elevations undefined
*Remove block visibility states
*Delete Hatches
*Make all lines solid - New Feature!
*Delete Plan Sets / Dynaview Boundaries
*AUTO RELAYER / REGROUP Linework into assigned layer groups according to National CAD Standards or the layer templates you set.
