I loaded up some of the custom RPS Custom Ribbons to work with. I now want to reset back to the default TBC Ribbons. I am not sure what I am missing, but after resetting the default ribbon layout does not come back. Can anyone see what I am doing incorrect? Thanks !
Have you tried going to the button next to it that says set ribbon tabs, uncheck the RPS tabs and check the standard tbc tabs? Or inside the set ribbon tabs command you can click reset to defaults. Hope this helps! - Trev
