Rename Drill Holes Command
Rename Drill Holes
  • The Rename Drill Holes command is part of the RPS Tool Shed Toolbox.
  • The command is located on the Tool Shed macros menu ribbon.
  • The command is located in the Drilling menu group.
COMMAND HISTORY
The command requires the v5.31 update to Trimble Business Center to satisfy the complete changes required for this workflow. v5.31 of TBC incorporates the following additional changes.
The Drill Hole Quality Report can now be executed with or without imported hole quality as-built data, meaning that you can now report Design Hole data only.
The Create Drill Plan command has been updated to allow for a skew angle between the Drill Plan rows and columns.
Provides the ability to rename/renumber drill holes in a drill plan, allowing for irregularly shaped boundaries, the addition of extra drill holes, and the movement of drill holes to allow for fault patterns through the drilling area. All holes are renamed uniquely and regularly along the rows and columns of the drill plan. Drill hole names/numbers can be defined using a user-defined name pattern.
The Rename Drill Holes command dialog looks as follows:
Drill Plan
Select the Drill Plan that you wish to renumber. Note that the Drill Plan type needs to be the Grid Type of Plan for this renaming command to work. Note that the origin and orientation of the drill plan are always honored in the renaming scheme; the renaming will start from the same origin points. If the project does not have any Grid Plan types, then the selection dialog will be empty.
The renaming process uses half the spacing of the rows and columns to determine which row an added hole belongs to. The added holes are assigned to the row and column based on their closest proximity within half the row or column spacing.
Name Mask:
Define the hole naming system that you wish to use, e.g., {R}:{C} for Row or {R}-{C} for Row-Column.
Start Column Number:
Enter the number for the first column of the plan.
Reverse Columns Checkbox:
If you wish to reverse the numbering system, check this checkbox. For example, you can start at 8 and reverse the numbering so that the columns are numbered 8, 7, 6, 5, 4, 3, 2, 1, etc.
Start Row Number:
Enter the first row number for the plan.
Reverse Rows Checkbox:
If you wish to reverse the numbering system, check this checkbox. For example, you can start at 8 and reverse the numbering so that the rows are numbered 8, 7, 6, 5, 4, 3, 2, 1, etc.
Results:
When you tap Test, you will see a preview of the results that will be applied when you tap OK. You can modify the settings as often as required, using Test to preview the results before committing the changes.
COMMAND TIPS
The Command Tips pane shows you how to access Help for the command (this web page) and provides other useful tips that may be helpful. You can minimize the Command Tips pane using the orange arrow in the top-left corner of the pane.
HEADER BAR COMMANDS
The following commands are enabled in the header of the RPS Rename Drill Holes command:
  • RPS Help
  • RPS Settings
  • Takeoff Lines
  • Smart Edit
  • Adjust Linestring Elevation
  • Create Drill Plan
  • Edit Drill Plan
  • Create Boundary
  • Create Alignment
  • Create Corridor
  • Create Surface
  • Add/Remove Surface Members
  • Create Surface Edge Breakline
  • Add/Remove Surface Boundaries
OK BUTTON
Executes the command, renames the Drill Holes for the Drill Plan, and closes upon completion.
CANCEL BUTTON
The following video shows how to utilize the Rename Drill Holes command:
The following videos show the use of the Rename Drill Holes command in a workflow context:
If you would like to provide feedback on the use of the Rename Drill Holes command or to request enhancements or improvements to the command, please click Reply below.
